I see all over the internet this myth that VDDG should be 40-50mv below SOC. This is a Chinese whisper if you ask me.
This is from the likes of the Stilt and 1usmus, but what makes them qualified to say this is correct?
Show me AMD words that say the same and I'll believe you.
The only official AMD words I can find come from the Ryzen master documentation that says VDDG and SOC should be started at 1.1v for ram (IF) overclocking.
Page 34
This bothers me clearly. As the one aspect I hate about overclocking is the unknowns and when certain things get thrown around as fact, when in the end they are just whispers which have became truths.
It bothers me because I think the VDDG voltage might be the missing ingredient to getting my ram stable, something I have not been setting as the dram calc claims that 0.950v which is stock was sufficient. (Hence my instability)
Anyway I've set both SOC and VDDG to 1.1v and if things are still stable in a good 3 weeks I'll know I'm in the clear.
Try CLDO_VDDP 1000mv I found this helped after Ramad mentioned over at OCN that he felt that it was too low by default and suggest 980-1000mv
CLDO_VDDG should be at least -40mv from SOC voltage. At least that always used to be the case.
, meant
