- 12 Jun 2006
I just can't understand how a monitor can be scratched inside the box it came with.
My monitor is also damaged. There's a big scratch on the top right corner of the screen and a big vertical lane right in the center. It's very noticeable when the monitor is turned off or in dark scenes.
Here are some pics, it's kinda hard to capture the vertical lane but it goes all the way up from the LG logo:
I'm really sad. It seems like LG's QC is non existent. Those of you who didn't get the monitor are lucky for not having to deal with this ****.
factory calibration on RGB spot on, didnt even need to change any RGB settings on display, nice colour gamut https://prnt.sc/pfyy3t vs my 4years old TN panel https://prnt.sc/pfz01u. also can't say contrast is bad, of course not OLED, but no problems at all
Benq TN panel in the left vs LG on the right. (TN is a bit on the angle so has a bit of glow in the right, but now glow if you look directly)
https://prnt.sc/pg3tdj
https://prnt.sc/pg3ukp
Just wanted to add some good vibes on this new LG Display, as there was some negative hype in previous pages![]()
So I've been out of the monitor game for a while, Why is there a 2 month gap on orders? lol
(though the matt finish isn't the greatest)
Well I have been wanting the 1440p monitor. Worried about lack of stock, and dont want to experience any issues.
But since showing an interest I have wasted some of my budget. 960gb ssd for one of my lads, new Steelseries Apex Pro, last night I ordered a spare Corsair gaming mouse and Seasonic Prime Platinum 650w psu.
Now wondering if 650w was a good idea, and still wishing I had a new monitor.
I feel for you, brother. Although in my case, I'm upto £1700 worth of spend!
The only thing missing from my new rig now is a 27 inch IPS monitor. I was going to grab the LG 27GL850, but I need the whole spend to be in by the end of my company tax year at the end of November; don't think the LG is going to by re-available by then. I'm also looking at the Viewsonic XG270QG, which uses the same panel, but whether that too will be availabe by the end of Novemeber I've no idea.
If anyone else has any good suggestions of what else I could be looking at as alternatives to the LG in the next couple of months I'd be glad to hear.
OCUK take the money when you pre-order so you might as well pre-order and use the invoice dated from then for your accounts.
