You need to read the post Ross Thomson was answering:I'm confused... @Ross Thomson says that it’s clearly been shown that higher end AIO are not any better than higher end air coolers, and @doyll disagrees with the comeback that a be quiet! Silent Loop 280 was as good at same noise levels as top tier air... aren't they both saying the same thing?
Rossi~ said: ↑
Except for decent AIO's from water cooling companies the likes of Alphacool and EK. IMO, are the AIOs to go for, not your run-of-the-mill Asetek jobs.
Ands it’s clearly been shown that these are not any better. ↑
Ross Thomson
~ said: ↑
Ands it’s clearly been shown that these are not any better.Ands it’s clearly been shown that these are not any better.
AIOs that are not CLCs are better than AIOs that are CLCs. CLCs are a sub-group of AIOs. AIOs have fill ports, threaded fittings, etc. so can be added to and/or repaired and usually have copper radiators while CLCs are factory sealed with aluminum radiators and no way to repair or add components to them. Hope that clears it up for you.
Still am. Even though AIOs are more capable of keeping up with top tier air and likey to last longer than CLCs they are still be bottom of the barrel of component H2O costing much more than top tier air cooling and not lasting near as long.Yet he used to be the resident AirCooled fanboy.
