*** The Official OCUK Cinebench R20 benchmark Thread ***
Caporegime
OP
17 Mar 2012
ARC-L1, Stanton System
Couldn't be fussed figuring it out again myself so used a calculator.
Also technically would you actually add those percentages together? Surely having a 7% increase in core clock doesn't equate to adding 7% onto your ipc.
Surly that's wrong given that your example calculation is a percentage difference value, not a base line to increase to get to an end value.
So if Value A is a score of 348 and the measure in that is 100% what added value in percentage terms would it take to a score of 506?
Take 348 as a value of 100% and add your example of 37% to it (IE make the value 137%), you get a score of 478, 37% of 348 = 129 add to the 348 value and you get 478.
Now take 348 and add 45%, you get about 505, 45% of 348 = 157 add to 348 = 505.
Then the difference in clock speed, which is 7%.
5 May 2017
This is the right calculation.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Managed to get this at 4.5GHz on 3600 at 1.25v. Had no luck with doing the same with all cores. That would need more volts and I think I do not want to go above 1.25v going forward as that increases temps and I would prefer not to push the CPU too hard which could maybe lead to degrading.
Below is my 4.4GHz so far rock solid overclock :)
1 Jun 2019
About time I added mine now that I finally did some sort of over clocking for 4.3Ghz All core.
I'm sure I can go higher but it's good enough for now.
A 7767, not bad at all for a 3900x on a x370 board. And over 400 higher than my PBO enabled score.
Add me to the MC scoreboard!:p
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Do single thread also if you can ;)
And yeah, add us @humbug
Please? :p
