- 30 Mar 2017
Poor quality pic (might have to right click on it) but finally in the watercooling club!
It wasn't actually as hard as I thought it would be.
You definitely have to take your time and triple check everything before adding the water.
Hardest part is cutting the tubes straight and attaching them securely.
I would have put the D5 Res/Pump vertical, but there was just nowhere else I could fit it, without hacking away at the case.
All the bubbles are almost gone now and the temps keep coming down every day as it bleeds air.
Using an EK RGB 360 Kit (D5, Supremacy, 360 PE rad) with an extra slim SE rad up top.
Maximus XI Hero with a 9900k. Temps are still in the 60s, 70s at most (spikes) under gaming load. Just using stock settings with XMP for now.
Voltage around 1.2v (load) max 1.25v (stock) I know I could get better results with this voltage but haven't bothered changing anything.
From what I have read that is fairly normal sharing the loop with GPU..That 9900K getting flipping hot.
GPU 2080 ti SeaHawk EK X. Temps don't go over 50c, overclocked +100ish. Boosts to 2100 and pretty much stays there.
Pretty happy after all the work.
Definitely could have planned better, but I think it works out well.
What do you guys reckon on the temps and build?
Thanks for any opinions.
