Modest settings for stable 3600mhz to try, I too had issues with Trfc, PC would **** itsself everytime I tried dropping that I got fed up doing cmos clears. Any room for improvements, dram calculators setting Twrrd being at 1 was causing me lots of errors set to auto its fine, I imagine that dimm voltage can be lowered. Gonna try Andries 3733 profile but this one will be my 24/7. The Ram is a bargain :
Vdimm 1.4, soc 1.1, VDDP 0.9, VDDG 1.0
	Anyone any idea why my latency is higher than user aboves? As far as I can see, Running almost identical timings bar rear row column delay, and other 2 main timings a little tighter but my latency is around 70.5ns on my 3700x.![]()
 it also has a higher CPUz single thread score at same clock speed than the TR
 Its a strong little CPU.
Well done OCUK nice prices on the kits as well!
Just need to stock Sabrent Rocket M.2 NVME drives now.
:O@Gibbo Good call, they'll fly out the door with all the recs on this forum & cheaper than the others as well
Wish I'd waited a few days as I would have bought from you guys![]()
We cannot compete with Rainforest on that, but we are pushing Corsair to match their prices with their MP510 which offers same performance.
Were also going to bring in the TeamGroup MP34 M.2 SSD which offers close to the performance but at a lower price.
Shhhh:O
you bought the sabrent rocket and e-die ram outside of ocuk!? Traitor you![]()
sabrent rocket is a MyDigitalSSD BPX Pro rebrandI believe the Corsair is based on the same tech as the Rocket, so if you can get them to match, that'll be a belter as Corsair have a much better warranty support etc...![]()
953GBsabrent rocket is a MyDigitalSSD BPX Pro rebrand
yeah, both the mp510 and rocket use the phison e12 controller with toshiba 3d tlc nand
just out of interest...what is the formatted capacity of your rocket 1tb?
ah thanks. guess the rocket has the full 1tb then953GB![]()
What's the others then?ah thanks. guess the rocket has the full 1tb then
i wonder if that's due to the rocket having less overprovisioning or using diffrent nand...
MyDigitalSSD BPX Pro "1tb" is also 960gb - same as the mp510 (894gb formatted capacity)What's the others then?
Using likely completely same components TeamGroup should perform similarly.We cannot compete with Rainforest on that, but we are pushing Corsair to match their prices with their MP510 which offers same performance.
Patriot VPN100, PNY CS3030 and Silicon Power P34A80 are other Phison E12+Toshiba NAND based drives.
