Ballistix Sport LT Overclocking
17 Aug 2017
Modest settings for stable 3600mhz to try, I too had issues with Trfc, PC would **** itsself everytime I tried dropping that I got fed up doing cmos clears. Any room for improvements, dram calculators setting Twrrd being at 1 was causing me lots of errors set to auto its fine, I imagine that dimm voltage can be lowered. Gonna try Andries 3733 profile but this one will be my 24/7. The Ram is a bargain :
Vdimm 1.4, soc 1.1, VDDP 0.9, VDDG 1.0
Anyone any idea why my latency is higher than user aboves? As far as I can see, Running almost identical timings bar rear row column delay, and other 2 main timings a little tighter but my latency is around 70.5ns on my 3700x.
v3Tx6y3
v3Tx6y3
9 Dec 2015
v3Tx6y3
v3Tx6y3
I heard it can be board dependant, also how many dimms are you using?
28 Jan 2003
Bristol
I am after some Ryzen gen 1 advice for this RAM if anyone has any, it's a long thread which mostly seems to focus on new chips.
I've got some 3200LT Sport running with my 2400G on an Asrock B450M Pro, obviously being an APU system memory performance is a bit more crucial to the machine, I have done some crude tuning basically finding out what speeds it will run at, in this case 3400 is all I can get to pass memtests regardless of how slack I make timings, so stuck with 3400 and started to reduce timing numbers, for the most part benches are reporting higher numbers for bandwidth and lower latencies than what I started with and gaming response on iGPU is improved which is all good.
But I don't really know the relationship between all the numbers and have just got here through long, slow trial and error, if anyone has a clue on what can improve this further, or if I have done something that could be negatively impacting performance let me know before I finally close the box and settle on what I have.
Cheers
Man of Honour
26 May 2012
@sandys ryzen/ryzen+ do not have great IMCs so 3400 is a pretty good result ;)
your pic is a bit small (and i cba to squint so can't really say if your timings are decent or not)
but getting cl14 is pretty good
28 Jan 2003
Bristol
Hmm not sure why it came through small, I shall have another try later.
Yes its 3400 is better than what I manage on my Threadrippers expensive 3600 B die RAM :( it also has a higher CPUz single thread score at same clock speed than the TR :( :D Its a strong little CPU.
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have Ballistix Micron E-Die on the way, ETA this week:
Crucial Ballistix Tactical Tracer RGB Micron E-Die 16GB Kit (2x8GB) DDR4-3200 UDIMM Gaming Memory @ £97.99 inc VAT https://www.overclockers.co.uk/Cruc...-DDR4-3200-UDIMM-Gaming-Memory-MY-20C-CR.html
BLT2K8G4D32AET4K, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.30-1.35v VDIMM, Lifetime Warranty with Crucial.
Only £97.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT Gray Micron E-Die 16GB Kit (2 x 8GB) DDR4-3200 UDIMM @ £74.99 inc VAT https://www.overclockers.co.uk/Cruc...GB-Kit-2-x-8GB-DDR4-3200-UDIMM-MY-20B-CR.html
BLS2K8G4D32AESBK, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.30-1.35v VDIMM, Lifetime Warranty with Crucial.
Only £74.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT Gray Micron E-Die 32GB Kit (2 x 16GB) DDR4-3200 UDIMM @ £149.99 inc VAT https://www.overclockers.co.uk/Cruc...B-Kit-2-x-16GB-DDR4-3200-UDIMM-MY-20D-CR.html
BLS2K16G4D32AESB, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.30-1.35v VDIMM, Lifetime Warranty with Crucial.
Only £149.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT White Micron E-Die 16GB Kit (2 x 8GB) DDR4-3200 UDIMM @ £74.99 inc VAT https://www.overclockers.co.uk/Cruc...GB-Kit-2-x-8GB-DDR4-3200-UDIMM-MY-20F-CR.html
BLS2K8G4D32AESCK, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.30-1.35v VDIMM, Lifetime Warranty with Crucial.
ORDER NOW
Crucial Ballistix Sport LT White Micron E-Die 32GB Kit (2 x 16GB) DDR4-3200 UDIMM @ £149.99 inc VAT https://www.overclockers.co.uk/Cruc...B-Kit-2-x-16GB-DDR4-3200-UDIMM-MY-20E-CR.html
BLS2K16G4D32AESC, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.30-1.35v VDIMM, Lifetime Warranty with Crucial.
ORDER NOW
Crucial Ballistix Elite Micron E-Die 16GB Kit (2x8GB) DDR4-3600 UDIMM Gaming Memory @ £188.99 inc VAT https://www.overclockers.co.uk/Cruc...-DDR4-3600-UDIMM-Gaming-Memory-MY-20G-CR.html
BLE2K8G4D36BEEAK, 3600MHz RAM Speed, CAS 16-18-18-36 Timings, 1.30-1.35v VDIMM, Lifetime Warranty with Crucial.
Only £188.99 inc VAT.
ORDER NOW
We can get other kits, but these seem to be the ones people go for.
OcUK Staff
17 Oct 2002
OcUK HQ
Well done OCUK nice prices on the kits as well! :)
Just need to stock Sabrent Rocket M.2 NVME drives now.
We cannot compete with Rainforest on that, but we are pushing Corsair to match their prices with their MP510 which offers same performance.
Were also going to bring in the TeamGroup MP34 M.2 SSD which offers close to the performance but at a lower price.
26 May 2018
Bewdley, UK
Ah that's good to know for my build thank you much rather buy from OCUK if I'm honest. :cool:
Man of Honour
8 Nov 2007
Outer Space
:O
you bought the sabrent rocket and e-die ram outside of ocuk!? Traitor you :p
Shhhh ;)
Actually I bought some G.Skill RipJaw V's better value than the Crucial but I believe it was either a mis-price or as it was the last one in stock, a clearance price?
@Gibbo I believe the Corsair is based on the same tech as the Rocket, so if you can get them to match, that'll be a belter as Corsair have a much better warranty support etc... :)
Man of Honour
26 May 2012
sabrent rocket is a MyDigitalSSD BPX Pro rebrand
yeah, both the mp510 and rocket use the phison e12 controller with toshiba 3d tlc nand
just out of interest...what is the formatted capacity of your rocket 1tb?
6 Jun 2008
Finland
Using likely completely same components TeamGroup should perform similarly.
Patriot VPN100, PNY CS3030 and Silicon Power P34A80 are other Phison E12+Toshiba NAND based drives.
12 Mar 2017
Ireland
They are the same drive, Phison does turnkey solution so lots of vendors just put their stickers on their two E12 controller reference designs. The difference between the two is that one has half the DRAM of the other, to cut costs a bit. The Sabrent Rocket, Segate Baracuda 510, PNY CS3030, Patriot VPN100, Team Group MP34 for example are the same 1/2 DRAM design. Corsair MP510, Seagate Firecuda 510, Silicon Power P34A80, Team Group Cardea II for example are the full DRAM one.
Easy way to tell the difference between the two is that one uses Nanya DRAM chips and is single sided up to 1TB, the other is always double sided and uses SK Hynix DRAM chips (though I'm not 100% sure on this). Performance differences are mostly negligible.
Props to OCUK for listening to what their community though, stocking E-die and more Phison E12 drives gives us more options to work with.
