No issues here. Looks great, mostly high settings off out now.... will pick up where I left off. Key rebinding looks like next thing to be done
You might want to set aside half an hour for the keybinds, there are tons of them lol
I can't get HDR to look right on this at all, turned it off for now.
I was just about to ask about HDR.
on console, they completely borked HDR and sort of faked the effect in some way. I heard they resolved this to an extent with a later patch (after I had finished the game) so I never checked it out. Maybe what your seeing is the same HDR result as console release?
I think DF covered it in a video
What is HDR support like on PC these days? I plan in playing via my TV.Yeah it looks dark and washed out like xbox did at launch. The PC version does have the new game HDR setting that fixed the consoles HDR but it does not look right to me at all.
No crashes here, have set it to dx12 everything on ultra with no aa or vsync as have an uw gsync monitor. Only completed first two missions looks awesome so glad I waited for pc release.
EDIT: just wanted to add I haven’t even checked what FPS I am getting as it really isn’t that kind of game. Have an oc rtx2080ti and it looks stunning and running smooth!
Rockstars response to my support ticket
Rockstar Games (Rockstar Support)
Nov 5, 10:46 EST
A Rockstar Expert from Directly has an answer for your question "Red Dead Redemption 2 - PC - Installation/Performance".
Click this link to view their answer and continue the conversation: https://rockstar-games.directly.com...e41280b56?et=2c99829d6e134e98016e3c3eec1d5ad4
Ryan B. said: "Hi, I’m Ryan.
I’m a Rockstar Expert and a Rockstar gamer like you. I’ll be happy to help you out today
Sorry to hear you're having issues with this, you're certainly not the first person I've interacted with having the same problem!
It does seem that there's an issue with this at the moment. We've reported it to the Rockstar team and are waiting to hear back on a solution.
Until we hear back from them or they officially announce a workaround I'm afraid there isn't anything we can suggest to fix this.
Some people have reported that deactivating anti virus or similar protection fixes the issue, you can try this but it's not an official fix.
The best thing to do now is to keep an eye on the Rockstar channels as any fix it workaround will be updated there first:
https://twitter.com/RockstarSupport
https://rockstargames.com/newswire
https://support.rockstargames.com
Sorry for the hassle this is causing, I'm experiencing the same thing!
Thanks,
Ryan"
If this does not resolve your issue, please reply to your ticket via email or at https://support.rockstargames.com/dashboard
If you do not respond to the expert or your ticket within 48 hours, we will consider your issue resolved.
I must be super lucky, it's running butter smooth. Don't forget to change the graphics API from Vulken to DX12 if needed. May help those with issues. Sadly, time for me to get to work![]()
Try switching HDR from Cinematic to Gaming mode, pretty much fixed the HDR problems that the earlier console versions had.
How do i change keybinds themselves? When i go into controls and keyboard/mouse there is only a few options but no keybinds to change?
