Yes, I'm on the verge of buying a Samsung Ecobubble 7kg or 8kg tomorrow from John Lewis which I should be able to get for £299.
Still not working with new brushes. Waste of £22.
I'm currently editing a video to show you what's going on during a cycle including buzzing sounds. I'll upload it later. It's the only way you might be able to give me a better idea of what's wrong with it.
I think my old brushes were probably fine. The length of the new ones is the same meaning my old ones were barely worn down. I smoothed them with sandpaper but then one of the carbon pieces fell out the holder to somewhere at the bottom of the machine while fitting it. Can't be arsed to find it so I installed the new ones. I can't get proper access to clean the commutator, but in the video, I show it being rotated by me rotating the drive belt, so maybe you'll get an idea if it looks ok or not.
There have been a couple of instances today where during a rinse cycle the drum made a few clockwise rotations to agitate the clothes, filled with more water, then drum made a few anticlockwise rotations. Other than that, I've not been able to get it to rotate again. it just fills with water, then stops, I have to manually nudge the dial to move it on at which point it will make a buzzing noise. Move it on again, fill with more water, and so on. Eventually I'm able to get it to drain the water and open the door to an empty drum. In the video you'll hear the gurgling from the pipes under the kitchen sink when it removes the water.
Not just that, but when I use just the dryer part of the machine, again, no drum turning and an even louder buzzing noise. I demonstrate that in the video too.
I've no idea if there's a motor issue, circuit board issue, capacitor, solenoid, or if it's even worth trying to unclip the drainage hose and see if there's a blockage. When you hear the buzzing in the video, perhaps that'll help you tell me if you think there's an electric issue or not. I'm not prepared to mess around with any electrics in it. The only thing left I'm prepared to try is seeing if there's a blockage, but it looks like it might be difficult to get the clip off where the drain hose is connected in the machine.
