Why not benchmark it on Ultra!
High settings is not for PC Master Race
Most likely because at Ultra max settings 4k a 2080ti is only getting 39fps with lows of 17. It would be a proper slideshow on anything else.
I know, that's the joke
Nvidia response: the solution is easy guys, buy two 2080ti’s if you want to play 4K.
SLi = Defunct on this game (and most other newer ones)
Don't be hasty. Give it a driver update or two and it’ll miraculously start working again.
Would anybody know why I might be getting particularly low, lows on my Ryzen 3900x?
Noticed it running this benchmark compared with Gamers Nexus for instance. I've done two runs at 4k/Ultra and gotten decent max and average frame rates, but my low frame rate was 7 FPS on the first run and 6 FPS on the second.
I ran the benchmark without afterburner so I wasn't monitoring the 'live' frame rate, nor did I notice an obvious stutter.
I'm sure my PC does something similar in Hitman 2 as well
Perhaps clean reinstall the GPU drivers? See if that makes a difference?
Nice to see Ryzen 3000 series CPU’s having higher minimums than Intel
Well it would appear the 5700xt out performs the 2070super.
Order of better performer:
2080ti
2080 super
5700xt
2070super
https://www.google.co.uk/amp/s/www.game-debate.com/amp/news/27929/newsAmpPage.html
