Is anyone else getting this...
When playing split screen the other person isn't levelling up at all and also can't change load outs etc. Because they always stay level 1. There logged in as guest under my gamer tag on xbox does that make a difference?
Had by best match on shoot house - 34 kills and 10 deaths, which is great, as I'm typically bringing up the rear in matches, with 20 odd deaths
Get returned to the lobby after scores are shown, then nothing - you can see the menus and whatnot, but you cannot select them! At best, if you press a button, about 3 minutes later it reacts.
