- 24 Jun 2003
So my PC is mostly just used for gaming and i was going to upgrade the CPU to a 17-9700kF but i am wondering if with more and more games being designed for multicore useage , would i be better spending the extra and getting the i9-9900KF with Hyperthreading so that its more future proof as it has 16 cores instead of 8 cores but something i'm not sure of is if a game is designed to use multiple cores , does it prefer to use the hyperthreading cores or actual physical cores , or can the games usually not tell the difference between the two and just use what ever core is available.
i plan to Overclock the CPU as much as possible for max single core frequency , i take it the i7-9700KF would do this better due to no hyperthreading.
early 2017 you don’t need more then the mighty 7700k cpu ryzen changes that for computing (not gaming) intel Come our tith the 8700k which was amazing don’t get me wrong and now amd nearly match intel with 3000 series but they won’t beat them? As I said nice crystal ball you have there
