Brazo
Brazo
4k 60 at 75 res scaling
Which is 1600p.
Let’s not kid ourselves here
Anyone using an ..i5 2500k?
Possible?
yes at stock speed with a GTX1080, 2560×1440, most setting at max and multi-sampling getting 30-40fps, i'm surprised how well it runs as I havn't even got it overclocked at the momentAnyone using an ..i5 2500k?
Possible?
Which is 1600p.
Let’s not kid ourselves here![]()
Sure but the other option was 1080p
and the x box 1 x would have upscaled as well right?
Pretty sure Xbox 1 X RDR2 is native 4K. 30FPS though but still impressive..
That's actually pretty impressive. Mines overclocked to 4.5 I think, but I have a 1070 so I imagine I'll see similar results to user Tombstone above.
I'd like to push the resolution past 1080 but I'm guessing if I want to hit 60fps at all then that's off the cards?
I just want ps4 level of settings but at 60fps
4K almost 30 yes and whilst textures are ultra that’s more about vram than grunt. Where it counts the Xbox uses low or lower than low settings. It’s not bad )unless you compare screen grabs) but it is what it is.The one x is native 4k, it really is impressive tbh. Only dips below 30 a few times. Uses the same Ultra textures as well.
me, i had 0 micro stutters until the latest update. its annoying as i now get about 15-20 fps more than i used to but it stutters randomly for no reason now. you could try turning on async in the ini file to see if it helps, ive yet to try thoughThe game was running great for me but the most recent patch has caused the game to now stutter quite a lot, anyone else experienced this and know of some kind of temp fix ?
This fixed it for me ..The game was running great for me but the most recent patch has caused the game to now stutter quite a lot, anyone else experienced this and know of some kind of temp fix ?
Possible?
Still running nice and smooth for me, I do have a gsync monitor as well so I don't know how much difference that makes.yes at stock speed with a GTX1080, 2560×1440, most setting at max and multi-sampling getting 30-40fps, i'm surprised how well it runs as I havn't even got it overclocked at the moment
This game is broken.....
Aye, its a trail tree!
