What res are you playing at and the FPS m8? That far shadow setting is a bit of a FPS hitter from memory.
Tried a trainer last night to teleport around and have a look at areas I’ve yet to ride to which was a laugh but unfortunately the new patch seems to have messed up the trainers infinite stamina etc which doesn’t appear to work.
One thing I have noticed since the patch is that the edges of everything on my screen, objects and such, are very "grainy" , they werent like that before. I dont mean jagged edges like AA but bitty, or grainy. Just very rough looking
Ditto. It completely reset my ALL my graphics options to defaults too which was incredibly annoying. Can't get it back looking and feeling as good as it did pre-patch![]()
Oh mine feels as good, if anything it actually runs better, its just this sort of grainy look around the edges. Most noticeable when I move the camera. However I have found that if I turn the Sharpening right down it goes away. Makes things look a little more blurry but I can deal with that as my eyes are blurry anyway![]()
I am thinking of getting this game in a day or two. I have a 2070 Super/3700x. I will be playing on Lg Oled B8. It only supports 1080p/120hz and 4K/60hz. No 1440p, bugger! What res would you guys play on? Higher graphical settings at 1080p/120hz or lower graphical settings and 4K/60hz?
Happy days!Use Wemod, it auto updates, I'm using unlimited horse stamina so I can gallop non stop all over the map![]()
Start at 4k and turn down detail until you hit a reasonable fps. That is IF the 2070 can do 4k at a reasonable fps. Otherwise get a 1440p monitor.
Andi.
Are the graphics just as good in multiplayer or is there a notable downgrade like in GTA 5 ?
