Uh oh
Same exact reaction here.
Tempted by the Shift X at the current price though.
Uh oh
Any chance of deal on one of the Bitfenix Shogun's with a noise dampening kit fitted?
Any chance of a deal on the Kolink Rocket?
No plans at this stage. Might be able to sort something on Monday though.
Any chance of sorting? Also after an Aorus Elite X570 board too.
Thanks in advance
@ChugNorris - not sure if this is your department but are there any deals planned on Cable Mod Extension Kits? After the carbon set.
https://www.overclockers.co.uk/cablemod-pro-modmesh-cable-extension-kit-carbon-cm-14a-cm.html
That'll be @OcUK - PREDATOR , he's back in tomorrow.
Which model are you looking at? will do a one off forum only deal![]()
noblechairs HERO Gaming Chair - Black/White - Limited Edition 2019 @ £269.99 inc VAT
Limited Edition 2019 noblechair, PU-leather in black with white stitching & accents, Comfortable padding, Superior ergonomics thanks to adjustability options, Supports up to 180kg
RRP £349.99 inc VAT.
Only £269.99 inc VAT.
ORDER NOW
@ChugNorris With the Lian-Li 011 Air RGB, is there any kind of fan controller in the case for the RGB control on the included fans? Are they intended to run off the mobo? Am I right in thinking it supports 280 radiators at both the front and top of the case?
Thanks
Ordered! So excited thank you OC team!
