Is this the correct version "Crucial Ballistix Sport LT BLS2K16G4D32AESE 3200 MHz"
Just got the red 32gb kit for £112.
Yes they are E-Die.
Ive read the 16gb 3000mhz kit is the best one to go for as it may clock slightly better than the 3200mhz? with the current offers there is only a couple quid between them so just trying to decide which is best.
Will be paired with a Ryzen 2600.
Thanks for the quick reply, will go for the 3000mhz. CheersTechnically yes, get whichever is cheaper the binning differences between the two is pretty small.
It stems from the fact that tRCD doesn't scale with voltage on Micron E-die so 3000Mhz with 16 tRCD is an ever so slightly better bin than 3200Mhz with 18 tRCD. This probably won't make much of a difference if at all, so get whichever is cheapest.
Nope.It doesn't post even with Gear Down Mode enabled?
SOC and VTT_DDR are already at those settings. Haven't tried messing with procOCT yet - my own experience is that it doesn't help at all but worth a try I suppose. Can't remember the exact values I set for tCL and tCWL, will check later.Did you set vSOC at 1.1v? Also try with ProcODT at 40ohm and see if that works.
Might be worth a shot to set VTT_DDR to half of the DRAM voltage.
Also make sure that tCWL is set the same as tCL, that can also prevent you from booting if the motherboard bios doesn't automatically set it right.
It stems from the fact that tRCD doesn't scale with voltage on Micron E-die so 3000Mhz with 16 tRCD is an ever so slightly better bin than 3200Mhz with 18 tRCD. This probably won't make much of a difference if at all.
It does, but honestly just get whichever is cheaper.
I'll do that. Cheers.
I suppose another thing I was wondering about was getting 2x8gb now and 2x8gb later, like in January or so. Assuming I get the same Ballistix Sport LT sku then the problems should be on the minor side? Or do I just aim for the total amount I'm after and get one kit?
I'm thinking with a bit fiddling it should be doable and it would save me some money in the short term, which at this time of year wouldn't be awful.
