Red Dragon is £360. I’d say better value and quality, as well as 0dB mode.Gigabyte Gaming OC 3X at £375 best value and very quiet !
Turn computer on got a black screen and my nitro doesn't even have any power going only ordered it 21/11. Any ideas? Second Card too after reference
What's your PSU?
Got a brand new PSU Super Flower.. Sort it the issue think it was DP cable playing up
From personal experience, a good DP cable is requirement for peace of mind.
Since started using DP1.4 HDCP 2.2 rated cable more than 2 years ago, stopped having any kind of issue.
Good idea, going to see do you recommend any particular brand?
Especially stop having to send the XL2730Z to Benq with flickering problems, even if used DP1.2a rated cable from 2015 when got the cable. (the one came with the monitor was DP1.1)
And all 3 monitors had to RMA during the 2y warranty period, suffered from that same issue after 5-6 months receiving the monitor and were brand new replacements all the time.
90C junction or edge? If edge check if fans spinning. Junction, ignore it.My Sapphire Nitro + special edition Temps still at least 90degrees, any ideas on to improve? Even with new driver update
What program do you use to check edge temp?
Any. That's the normal temp recorded by all software including the drivers.
Junction is the sensor deep inside the GPU for boost purposes, which AMD publishes on the API.
Nvidia has one too but isn't accessible through to the drivers.
GPU Temp is 72c, and junction is 99c. Normal settings all okay?
Okay I get you now, trying to undervolt with new drivers, how do you increase memory use to 900MHZ on previous driver can't seem to find it.
