So you bought a X570 board anyway lol. Simply for the latest ucode?
For some support and rid of annoying bugs that ASUS have failed at resolving.
Yes chap
Nice setup Scone
How easy is it to replace ram on that?
Room for tall ram for instance![]()
I'm a complete Ryzen noob, and I'm getting really confused with all the temperature readouts I'm seeing on my Asrock Aqua.
In the BIOS it's showing my 3950x CPU idling around an extremely high 60c, whilst HW Monitor is also showing that reading. However the Asrock A-Tuning software is showing my CPU idling at around 40, the motherboard temp is around 40c, the SB TSI CPU is around 50c whilst the SP TSI BIXBY is around 60c.
My liquid temps are only around 37, which considering it's over 30c today ambient isn't too bad.
I have no idea what I'm looking at here?![]()
What's your cpu package power when fully loaded in cinebench?Tightened down with my best b-die kit, GSAT stable.
OK, I've installed HWInfo, and this is what I get at idle:Try hwinfo as that's usually pretty accurate.
CPU(Tctl/TDie) - Varies wildly bewteen 45c-55c)
CPU Die - Around 40-42c
CPU CCD1 - Around 40
CPU CCD2 - Around 40
Is there anything to be concerned about there? Keep in mind it is quite warm in Australia at the moment.
Edit: If I do a Cinebench R20 run the temps of all 4 of those above go to 72-77c.
Yeah straight out of the box my 3600x would do 4.4 but it needed crazy volts, 1.487 was the highest i saw, but she is 4.25 @ 1.3125 now. sorry dude i am a bit of a noob when it comes to this, what i did in ryzen master was like you change frequency and adjust the voltage up to an acceptable level. i dont use prime though, prefer realbench.Over the years I have overclocked a few CPUs. However yesterday was the first time I have tried with a Ryzen and using Ryzen master. I am now having difficulty getting a stable system.
I have a 3600 with an aurous pro x570. In Ryzen master I could get to 4.225 at about 1.32v and was ok in Ryzen master stress testing. I was locking all cores and only changing the multiplier and vcore. however when stress testing with prime95 or even upon rebooting it kept crashing or doing the blue screen of death. I then even tried changing the multiplier to 42.25 and vcore to 1.43v in bios manually and could not get a stable system.
using hardware monitor at stock I see the 3600 briefly going to a max of 1.475v to give a max 4.175 - so to me it seems as if for my cpu that it briefly needs these high voltages. Note that when in games or stress testing hwm is typically 1.32v for 100% load.
any advice?
yeah finally got around to it today. using the ryzen dram calculator 3600 safe profile. am going to either try and get 3600 @ c14 or 3800 @ c16 when i am off at xmas but for now this will do. gained 5 points in r20 which gave me a score of 3857.Go for the 4.3Ghz. 1.35v is fine, hell my 3600 runs at 1.38v stock under all core load. You should try tightening them ram timings up, that will give you more of a performance boost in stuff like games over a few Mhz on the core.
if you got b-die , 3600MT with c14-15-14-28-42 defo achievable
