holy moly, this makes my planned Node 202 mod positively spacious!
Full stainless steel or chrome-plated copper hardline loop to match Watercool's Heatkiller blocks. Big trick though is flipping the CPU over so you can actually see the block, which instantly means it has to be single-slot width and give enough space underneath to allow the TX240 rad to breathe.haha, what you planning on doing to it ?
I have the case, I have a couple of prototype inverted GPU mounts printed, but I have no funds to buy the hardware and no reputation to even consider asking for sponsorship. The spec I have in mind isn't even that mental either![]()
Watercool offered me a 10% discount on their shop because I have no track record to support anything bigger, but I've not spoken to anybody else primarily because Asteria II isn't even finished yet, and I'm paranoid that spending over 3 years to do my first project would actually be seen as a negative. Plus I don't have the big social media presence yet either, blah blah blah.
Anyway, enough moaning about my stuff!
 nothing quite like high res images with masking tape still on! or kids toys rammed into a custom £300 Parvum case pmsl
 but had to sell it on because of money. Kit wise I'm not looking at anything mental. It was a B450 board with 2600 and a decent 1080p gaming card that is either single slot or could be modded as such. Since July, I really want it to be a 3600 and 5700 (doesn't even need to be the XT).
 ). So more than likely I'd a new PSU for the Node project as it'll be all-new kit.Maybe. I got something new in for Asteria II so I have my old Silverstone ST45SF-G V2 450W Gold, but that's Christ knows how old now and was earmarked for Asteria Reprise (another 75% planned and drawn project). So more than likely I'd a new PSU for the Node project as it'll be all-new kit.
 5mm tallerHeart's set on the 202The project name is even based on it..."Dioxidane".
Hey Orbi@Plec @tamzzy after waiting 3 weeks! longer cooler Master Cable has arrived and can confirm old one was damaged !
Managed to do some testing with stock CPU speeds and overclocked to 4ghz all cores (running non X 2700). Aorus Xtreme 2080 running at default speeds without overclocking as well.
Max temp reached was 75c when stress testing with the GPU, which is quite surprising. was expecting it to be higher and 2700 was 65c with overclock running Cinebench r20 .
Gaming wise, 45c for CPU . Amazed at how well thin rad and fans hold up.
<snip>
Or to go FULL WATER!
