- 1 Dec 2015
Love all this custom stuff! Great work!
one issue im hitting- not sure as airflow isn't set up. Black screen and system crash with middle fan shooting to 100% speed.
Hmmm, from gaming or just idling? Under what circumstances does it do this?one issue im hitting- not sure as airflow isn't set up. Black screen and system crash with middle fan shooting to 100% speed.
Could be bad Sata cable as well, i had a similar issue where a bad cable caused me black screens and fans to a 100% because it would feed an intermittent signal. Replaced that and it was all fine again.just idle . fine before I took out of old system into new.
I have a feeling might have damaged PCIe cable a little due to taking out the card and case so many times whilst modding . do plan on getting a new cable once everything is in place
That PCIe cable has taken a lot of punishment over the past couple of months - didn't look particular healthy in one of the pics(?). Your gut feeling may be correct.I have a feeling might have damaged PCIe cable a little due to taking out the card and case so many times whilst modding . do plan on getting a new cable once everything is in place
Sob story email to Silverstone, they've been great with support to date?
Ah, forgot about that neat work around - direct appropriate 'worded tears' towards them, you never knowBeen great but PCIe bracket was cooler master vertical mount kit, so need another one to use that cable for its mounting points to the bracket etc
These extra bits are starting to mount up :/
#shouldvejustgoneitx
Crikey that's thin!
Crikey that's thin!
The stock fans are the noisiest part of the build. The motor isn't the best. If you want to change them, the prolimatech isn't a bad shout.
Dimension 120 x 120 x 15mm
Bearing Double Ball Bearing
Net Weight 91g
Fan Speed PWM 400 ~ 1300 RPM
Noise Level 7~17 dBA
Airflow 56 CFM
Connector 4 PIN PWM
Rated Voltage : 12 V
Rated Current : 0.12 Max. Amp
Input Power : 1.44 W
Input Current : 0.12 Max. Amp
MTBF : 100,000 h / 35℃ or 60,000 h / 60℃
Static Pressure : 0.9 mmH2O
Connector & pin-configuration :4-pin PWM
Bearing :SSO2
Blade geometry: A-Series with Flow Acceleration Channels
Frame technology :AAO (Advanced Acoustic Optimisation)
Rotational speed (+/- 10%) :1850 RPM
Min. rotational speed (PWM, +/-20%) :450 RPM
Airflow : 94,2 m³/h /55 CFM
Acoustical noise : 23,9 dB(A)
Static pressure :1,53 mm H₂O
Speed 2000 rpm
Airflow 32.6CFM
Static Pressure 1.52mmH2O
Noise Level 23.5dBA
1,500 revolutions per minute
- 25 CFM delivery volume
- 0.86 mm H2O static pressure
- Low volume of only max. 18 dB (A)
Yeah the prolimatech fans are regarded as the best slim fans from what I've read
Lol!HAHA
If you're interested in a little collab I can help design and laser cut an acrylic front panel. It'd be a shame not to go custom considering the heavy modding all over this case!
