Always makes me laugh PC gamers that argue about graphics, image quality, which one is better etc. yet most are still using crappy LCD displays with horrendous bleed, poor blacks + contrast ratio, glow etc.![]()
Except the fact even on the "crappy LCD display", it is very easy to tell the game image between AMD and Nvidia apart...Always makes me laugh PC gamers that argue about graphics, image quality, which one is better etc. yet most are still using crappy LCD displays with horrendous bleed, poor blacks + contrast ratio, glow etc.![]()
I didn't realise that Nvidia image quality was so much better then AMD..I think if you were to put a same game scene on two of the same monitor, I'd bet 95%+ of the users who have used both Nvidia and AMD over the years would be able to tell which is which in a blind test, simply because of that's just how great the imagine quality difference is.
Yea, just like Beats headphones sound so much better than Sennheiser, AKG and Beyer headphonesI didn't realise that Nvidia image quality was so much better then AMD..
Thanks for pointing this out..![]()
What she not heard she don't knowYea, just like Beats headphones sound so much better than Sennheiser, AKG and Beyer headphones![]()
Yes the side with 50% higher frame rate must be the 1050Ti and the slower side must be the RX570Well that would be easy, the one with the much higher FPS counter numbers in the corner of the screen would obviously be NVidia.![]()
Because you need to bump Digital Vibrance up a notch or two for Nvidia but I am sure this is for Desktop Colour only.
I used to way prefer CCFL backlights for a long time to modern LEDs - for awhile it was like staring into first generation ultra-bright LEDs with a slightly icy blue hue to it that was horrid but the latest monitors on most the backlight hue is fairly neutral.
CCFL were great but the warm up time was a pain in the ass. It took maybe 15 - 30 minutes to fully warm up.
At least on the models I use I only had any problems like that after they'd been through well over 10 thousand hours of use by which time I'd normally moved on anyhow - at 100% brightness they might take a couple of minutes but I usually used around upper 30-50% somewhere and they'd be warmed up from a cold start by the time Windows had finished loading.
Cheers for the comprehensive post, JasonM.![]()
