Sure if you are counting/concerned with people who just use their PC to check their email and surf the net.Most likely 95% of PC users would have no need for more then a 4 core cpu
I'm not sure I consider that to be relevant to this discussion tho.
Even the 4 core (4770k) PC I have downstairs for the kids to game on I can't see it needing upgrading in 2020 just because it has a 4 core cpuSure if you are counting/concerned with people who just use their PC to check their email and surf the net.
Am not jumping again into the most core count fashionMaybe not before the new consoles launch, but after it'll be a different landscape.
When PS5 and Xbox SX both have a modern Zen2 8-core CPU, devs aren't going to waste too much time optimising for 4c/4t PC CPUs any more.
You'll probably get a sub-par experience on those CPUs in 2021 and beyond.
Ryzen at 2.8Ghz would be crazy efficient. 4-5 watts per core?
yeah these seems more in line with what I was thinking. I dont expect it to hit the same ghz level as the desktop cpu part, but I do expect it to be in the high 2's or low 3's range
I'd say a safe-ish bet is 8 core. Considering the way consoles are going (custom 8 core AMD chip)... seems sensible![]()
6 core will become the base standard next year.
Looking at cinebench single thread scores there is no meaningful difference between a 3700x and a 3950x.
So the only benefits of the ‘better’ Ryzen CPU’s are more cores(?) But can we realistically make use of those cores?
Is eight cores the new ‘four’?
Is having 16 cores only for niche use?
Isn’t eight cores simply overkill for most desktop consumer software?
Are you honestly going to buy a Ryzen for use in 2020 and then replace it before the year ends?
Surely it's better to ask how many cores we'll need in 2022 so you've got an extra couple of years use out of it?
Ironically I did just that in 2019, bought a 2700x in January and then a 3800x on Black Friday
I think many on here change their cpu like
their socks! Maybe even more frequently
But no the thread was started to get a picture of where we are today now that all the Ryzens have landed.
My total ‘upgrade’ fee was £160 after selling free games and old cpu so not end of the world!Its easy with AMD due to the AM4 socket. You literally just buy a new CPU and replace - and given a reasonable sell value for the previous CPU, you're not even spending anything overly crazy to get it
Are there any tests out there that disable cores on current CPU's and benchmark them? Gaming-wise how much performance do you lose, say even a 9900k @ 4 cores vs 8? are the extra cores really giving a big boost in gaming or is it mainly the IPC improvements?
