- 21 Jul 2005
- Officially least sunny location -Ronskistats
Using 19.9.2 - and it's done it again, back to default voltages on boot up this morning.![]()
Are you using DDU uninstaller?
It's generally just bust, I gave up on Wattman a long long time ago![]()
Did you turn off Windows 10 Fast Boot?
Maybe your undervolt is unstable? Does it do the same at default voltages?
Have your turned off fastboot under Windows advanced power settings? Have you done a clean install or used the latest DDU?
Check your bios for fast boot up or something similar I disabled few things as suggested on this https://www.reddit.com/r/MSI_Gaming...eded/?utm_medium=android_app&utm_source=share
Didn't know they were so broken
You might eventually get some working drivers soon. Steves had a word
Yeah no mention of the dark screen bug after installing 2020 type drivers with my vega 56 and my Q3279VWFD8.Dont think ill even try them to see if its fixed but not mentioned as so far touch wood the computers ok atm.
Ddu still the best option?
