 - 4 Jan 2020
Hi All,
First time poster on the forums but long time lurker.
I have recently decided to take the plunge and build my own watercooling loop after many years of building pcs on air and having a room that heats up like an oven. The issue is my GPU is currently running what i believe is way too hot for a water cooling loop.
My PC specs
CPU - AMD 3950x - PBO on no other overclock
GPU - Asus Strix 2080ti OC Edition
Overclock settings for GPU via MSI Afterburner
Core Voltage - +0
Power Limit - +125
Temp Limit - 88C
Core Clock - +175
Memory Clock - +1000
RAM - Corsair Vengance - 3600MHZ
Motherboard - Gigabyte X570 Aorus Elite
PSU - Seasonic SSR-850FX FOCUS Plus Gold 850W
I have currently in my loop (im pretty sure this is overkill but wanted to be sure)
2x EK-CoolStream Classic SE 360
6x EK-Vardar EVO 120S BB (700-1150rpm) Running at 100%
1x EK-XRES 100 Revo D5 PWM (incl. pump) Running at 100%
1x EK-Velocity - AMD Nickel + Plexi
1x EK-Vector Strix RTX 2080 Ti RGB - Nickel + Plexi and EK-Vector Strix RTX 2080 Ti Backplate - Black
I have my loop order of Pump/res > GPU > Radiator > CPU > Radiator > Pump/res
Before the loop on air my temps were
CPU ran 75-77C under full load for 15 mins with an NHD15 with fans fixed to 70%.
GPU ran 75-78C under full load for 15 mins with stock cooler set to 70% overclock has been stable for around 3 months with not issues or changes to the above temperature.
First Loop attempt
CPU ran at 70-72C under full load for 15 mins
GPU ran at 87C constant and thermal throttled I stopped the test after 5 mins
Currently with my loop my temps are
CPU runs 70-72C under full load for 15 mins
GPU runs 78-81C under full load for 15 mins
When both ran together under full load for 15 mins the GPU runs at around 83-85C and the CPU runs between 78-81C
Initially I thought the issue was poor paste spread on the GPU, so i removed the water block and confirmed that this was not the issue but i believe that i hadn't had enough mounting pressure as the thermal pads looked untouched on the GPU.
I removed the old paste and reapplied some more in the same method as previously done and made sure to tighten the screws harder this time using the provided screws and plastic washers.
I did the same for the CPU and removed the old paste and reapplied new and re-tightened.
Both paste spreads fully covered both the IHS on the CPU and the entire chip on the GPU.
Tested again and as you can see above the temps are better but still are running awfully hot I believe.
Is there any suggestions as to what may be the cause of the issues and if so any advise would be amazing, im really out of ideas as to what could be the issue.
Or am i just expecting to much out of the loop and it should be that hot?
Loop picture below
Thanks all,
Josh
My PC specs
Core Voltage - +0
Power Limit - +125
Temp Limit - 88C
Core Clock - +175
First Loop attempt
Loop picture below
	Thanks all,
Josh
