- 4 Jan 2020
not to be funny but you did wash out the rads first ? could be as simple as blockage on the blocks ..or pump
with the thickness of those rads cant see static pressure being a problem ..
I did yeah, loads of crap came out of them which i was kinda surprised about considering they are tested and new :/
High static-pressure fans on the rad (Corsair SP series, Akasa Viper or Piranha for eg) and get a rear exhaust fan in there- can't see one on your pic.
I'm thinking it's lack of case airflow, pure and simple.
I have now added a rear fan as suggest by a couple of chaps and will see if this improves, my old fans that i was going to swap out to test are only 1200fpm fans so i don't think that would make a blind bit of difference so i have ordered some new ones with a bit more umph and will test
