Upgrade from 1070 to 2070 and performance lost.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Urgh, i hate reinstalling windows :p
Noooo, i hate reinstalling windows :p
650w
Cpu pulls 150 ish, gpu while overclocked is 370 ish
Feel free to continue looking for a way to fix things online then. Doing a clean install when browsing on phone or iPad can be done in an hour or so. Much quicker imo.
21 Jan 2016
Just FYI I don't know what cooling you are running but I got more out of my 2070S perf wise by under volting… might be worth playing with. Power draw usually stays below 90% but clocks are higher due to more stable boost. Stock but with power and thermal slider maxed it would drop down to mid-low 1900's even with fans at max during gaming while pulling around 112%... undervolted it will happily sit at 2010-2025 all day long.
While I don't think it would explain the problem here it may not be helping you get the most out of your card.
OP
17 Dec 2006
Loughborough
370W? My 2080Ti running at 2100/8000 draws less than 300W.
Just how OC’d is your 2070S!?!
I meant 270, my bad :p Its around 220 as standard.
Running power limit slider on full, core voltage on +2 and core clock is +90 and memory is +700. It seems quite happy in ark at a constant 2055mhz at 60 degrees with 30% fan speed and boosts up to 2090 in other demanding games.
4 May 2004
NE England
If I am reading this correctly you are overclocking the card? What happens when things are factory speeds and I assume you are using some monitor/tweaking program (like MSI Afterburner)? Uninstall that software and reinstall drivers via DDU.
OP
17 Dec 2006
Loughborough
Same pc, same benchmark, same settings. 1070 vs 2070 super. not sure why the minimum frames are lower though, couldn't tell they had happened during the benchmark.
Well, bit of a thread revival but new 5600x, ddr4 at 3600 and a fresh windows install later. Same 2070super
I think my 4790k and ddr3 was holding me back a bit in ROTR and it gets much better scores now. I doubt anyone cares but i'm happy now and thought the thread could do with a conclusion.
16 Jan 2006
Nice result, was a CPU bottleneck definitely.
Always makes me laugh when people say 4core/8thread CPU will be ok with modern GPUs.
My 4790k’s soldiering on thanks. Had a huge iq uplift in everything I play on 60hz screen moving from a 1070 to 3070 between 1440 and 4K
ACC
RDR2
MSFS
Cp2077
DCS
MSFS and CP are still mainly GPU limited.
I know things would improve with the 5900x I’m thinking about but in no urgent hurry
OP
17 Dec 2006
Loughborough
ACC
RDR2
MSFS
Cp2077
DCS
In high fps (tbf you probably wont notice on 60hz screen) games i was having stuttering, fps drops little micro pauses and the whole thing felt remarkably unsmooth. Going to the 5600x and all of that is gone. I just get way more stable frames now. Rendering clips for youtube is literally half the time now which is insane.
You can see if you compare my SOFTR benches it's a 10%+ boost to mins, max, avg, 95% across the board. Using my 120hz monitor, going from 90fps with drops and stuttering to 110-120fps and smooth feels like a night and day difference. Heck, with the 4790k ROTR had a min frame at one point of 6fps. the 5600x in the same section had a min of 41. thats bonkers.
Man of Honour
13 Oct 2006
Not a CPU bottleneck something else wrong - I went from a GTX1070 to a GTX3070 with a 4820K and saw a huge uplift in everything, then swapped to a 1650 V2 which has helped in games like Cyberpunk.
4 core / 8 thread still holds up in most games except a small smattering of newer ones.
OP
17 Dec 2006
Loughborough
I would say it was that AMD gaming ram bottlenecking the intel system ;)
:p Not sure if sarcasm or not but the tech specs were:
Capacity: 16 GB / 2 x 8 GB (Dual Channel)
Clock: 2400 MHz
Latency: CL 11-12-12-31
Voltage: 1.65 V
Tighter timings than corsair vengeance pro that runs at 11-13-13-31.
OP
17 Dec 2006
Loughborough
You will see a big improvement, but you won't see AS BIG of an improvement as the card is truly capable of. So swapping from a gtx1070 to a 3070 you'd be getting 80% of the 3070's fps instead of 100%.
16 Jan 2006
Let’s put it like this....
you have a 4790k and a 1070.
someone offers you a full platform upgrade to say a 5900x or a 3070...which one would you take assuming you couldn’t sell it?
it’s a complete no brainer. The extra £800+ outlay of the new platform would be nearly double the GPU outlay for much less gaming benefit. Even if you just said 5600x it’s still £500+.
I just don’t see the essential nature of moving from a 4790k. Very desirable yes, necessary and worth the money...not really otherwise I would have done it by now.
16 Jan 2006
That’s what happens when you unlock the above 60hz Pandora’s box.
