Don
- 20 Oct 2002
- Oxfordshire / Bucks
HOW MUCH
We always knew it was going to be this price. It's a fibre optic cable, and it sells for as many dollars in the states- it has always cost the UK more (After currency exchange is taken into account) for American tech.HOW MUCH
I knowHOW MUCH
It's been compatible with the DAS for donkeysWhats intriguing is he says early on "its also compatible with the Vive Audio strap". Didnt know this fit the Quest !
Or simple sticky-back Velcro. Not that it matters, because the DAS is discontinued alongside the Vive, so you'll have a hell of a time finding one that still has the headphones attached.It's been compatible with the DAS for donkeys. You just need some 3D printed parts to make it attach.
They have been coming since Feb 2019It is disappointing that the cable seems to be priced even higher over here. Still, as the specs are being made public hopefully we'll have some third party cables at some point.
what type are you looking for? Permanently attached, buds or actual headphones.Just recently got myself Quest and the official link cable and it performs and works very nicely.
Can anybody recommend some good headphones for the quest as i am not that impressed by the audio side of things.
Buds will be finei have seen the official ones for £50 but peeps say you can buy one for £20 which sound just as good.
Just want decent sounding ones.
Can only speak for what I have used.
Made two separate out of a pair of Xiaomi Piston IIs, bought some L-3.55mm connectors and soldered on. Fitted some mem foam tips so they stay in. Great sounding.
Just out of interest which L 3.5m jacks did you get ?
Ah ok I've ordered two stereo ones (solder) off the Rainforest arriving tomorrow I cant wait that long for them to come from overseas.https://www.ebay.co.uk/itm/183815623803 the 3 pole version. Once soldered squirted a bit of superglue down the small gap at the end to hold everything in place.
