Is there a way to disable hdmi sound?
Dad uses skyq hooked to a monitor with cheap speakers built in. Bought a soundbar to use for it instead, hooked up over optical. Is there a way to disable hdmi audio? Closest I've found is set the hdmi audio to dolby digital, and then on hd channels the monitor won't output sound (doesn't support it), but sd channels will still have sound. Annoying to keep having to turn down the built in speakers. Is there a setting somewhere to just disable audio over hdmi and only output to optical?
Not sure if I'm missing something in your post but this is the same for every AVR user with a Skyq box albeit the tv does decode all audio, I just use my AVR for all sound and turn the tv volume to 0.
Can you not just turn the monitor volume to 0 and use the soundbar for all sound.
