Any one here have a UDM? I have an AP-LR and whilst it's many times better than my SH, there are still outer parts of the house that are a bit flaky. I fancied getting fully onboard with the Unifi ecosystem and to learn more about networking (another AP, possibly a USG and definitely a switch). However have just come across the UDM which seems to do everything.
Combing through the thread and just seen this which has made me ponder. Apart from the back kitchen* the WiFi in the house is pretty good. The easiest upgrade would be to simply add another AP in the kitchen to cover that and the garden. However I would like to hard wire my computer upstairs as whilst it manages to stream just fine from the HTPC downstairs, it can struggle at high bit rate 1080p and it's not even worth trying 4K
. The house is rented though so the wiring/trunking solution needs to be easy and easy to remove (back of living room, across the ceiling, a very short distance across the hallway ceiling, through the banisters and then under our bedroom door - the room is basically directly above). My DIY skills are pretty shoddy but I can learn. I would also like to hard wire the HTPC which sits right next to the AP-LR.
*I wonder if my wife's S10e has a weaker radio than my older Note 9 as her WiFi is a lot more flaky than mine in the kitchen.
