always apply the anti-fog inside, a while before, so it dries, usually put just a couple of drops (taking top off of spray bottle) and using finger tip. ..
one bottle last for many years. ... pity the goggle skirts only last a couple
I put it on the night before, so I don't forget ... well, later this evening - lolso would putting in on at home, say 2 hours before you get into the pool be ok ?
YES !
I am now moving UP to the next class !!!
4th move now
will be hitting ADVANCE course next term (after 4 weeks)
I am REALLY PLEASED and HAPPY
Only after a decent distance and usually in feet or calves, might be too much tension in your hand maybe?Anyone find they get hand cramps whilst swimming? I've had it a couple times now in my left hand, wonder if it's down to doing too much or dehydration perhaps. I normally take a drink with me but may try an extra one before the swim too
Nice
I can only manage 550m at the moment, but I think it might be tention , maybe your stretching your fingers out too much and your bending them back ever so slightly
I get cramps in my feet occasionally I know that's down to tention, wrong feet position
We used some hand floats last night, cant find them online, they are round with a hole in the middle for your thumb , they were brilliant, want to buy some
Cheers, I tend to do about 2-2.5k per session and it comes and goes. I thought it may be tension too so I'll keep a mind on it next time and see if it helps with a slightly relaxed/open fingers.
On another note, anyone use/recommend paddles? I never used them when I was much younger and swimming at county level but see quite a few folk using them now and apparently they can be good for building upper body. Gather they take a while to get used too and probably not a good idea yet with the hand cramps
Something like this perhaps? - https://www.proswimwear.co.uk/finis-agility-floating-paddles.html
They look like they're foam
