- 27 Apr 2007
A stronger intel will be good for competition as at the moment the top end pricing for Desktop and HEDT is much higher than it’s ever been.
We don’t want a situation where that becomes almost normal as it has with GPUs.
Well that's just complete horse. Not even remotely true.
If you look at what I actually wrote you will see that you have missed the point I made.yep it's not true at all. I've love that person to show us how the $ per core has supposedly gone up because it looks like it's gone down. for instance let's look at high end desktop the 3950x $ per core is nearly half that of the 9900k and 8700k. So how can anyone try and say it's become more expensive
I said that PRICES at the top end are MUCH higher than they have ever been and I didn’t mention performance per $ or cores per $.
I was thinking more of the last 10 years as prior to that we did see the top bin desktop chips going for $1k but that’s a long time ago.
My point is that 5 years ago in January 2015 at the top end we had:
i7-4790K 4C 22nm $350
I7-5960X 8C 22nm $999
Now we have:
RYZEN 9 3950X 16C 7nm $750
RYZEN THREADRIPPER 3970X 32C 7nm $1,999
I’m ignoring the 64C chip as it’s in another class and doesn’t change the argument I am making.
Say that TSMC’s 7nm is roughly equivalent in density terms to Intel at 10nm.
So in 5 years we have gone through 2 full node changes which equates to roughly quadruple the silicon
density.
The number of cores have quadrupled also so that’s a good fit unless the cores are much more complex.
But prices have at least doubled in this timescale as the figures above show but without getting significantly more silicon for this doubling.
Wafer costs have increased but does a 3950X cost so much to make that a $400 price premium is warranted for the silicon size?
The 3950X doesn’t have an iGPU which helps reduce the size and cost, plus it's made of small chiplets which have great yields.
So there are also factors here which are actually lowering the cost versus 5 years ago.
The 3970X doesn’t have an iGPU advantage versus the Intel HEDT chip but it has a bigger gain in the chiplet department as the Intel chip is monolithic and big with it, so the yield advantage is greater than with the desktop chips which is smaller in Intel’s case so has less of a yield issue.
Does a 3950X cost so much to make that a $1,000 price premium is warranted for the silicon size?
I don’t think so for either Desktop of HEDT but I blame Intel for the current high price of CPUs.
Firstly, because in mid 2016 they pushed HEDT up to $1,750 from $1,000 which set the precedent.
Secondly, they haven’t been able to get past 14nm so they can’t compete in terms of transistors per chip, hence the lower core counts.
Without competition AMD have been able to extend the top price point and especially for desktop.
Without these two things from Intel we may well be seeing proper competition with 16C for $400-450 and 8C at $200; for current generation.
The irony is that Intel have created a situation that allows AMD to push the envelope pricing wise which must mean their margins are amazing.
The downside is that current prices are roughly double what they were 5 years ago for the amount of silicon you get.
So as I said in the initial post, the danger is that this becomes normal as with GPUs.
So we need Intel to keep AMD honest and AMD to keep Nvidia honest.
Maybe some of you were confused because you weren’t around when chip performance per $ would increase regularly without the actual prices doubling.
