255/35/20 doesnt seem particularly bad for rubber price wise £120 seems to be decent branded rubber as i said the MP4s are £150 a corner but its a diesel taxi, it doesnt really need Super high performance rubber to trundle up and down the motorway all day a decent branded tyre will be fine.
that said an extra £30 a corner really isnt a big difference, just curious to see what the options are
as long as its not the standard Dunlops
Bugger just missed costco offering £50 cashback when you buy 2 michelins offer, would have brought the MPS4s down to £125 a corner or there abouts, no brainer at that price. cracking tyre/price
What tyres would you guys recommend for a Ford focus, size is 205/50/R17?
Thanks
Is there any guaranteed way to find out if a tyre is a run flat? Wife's Mini needs a new front tyre because of a tracking issue, I assumed BMW/Mini came with run flats but there is no indication that they actually are.
They are Michelin and there is ZP that I can see.
Run flats aren't standard on most of the Mini hatch models only an option, the tyre will have run flat printed on the sidewall if it is one.
Depending on the current tread level you might need to replace both front tyres. I wouldn't want more than 1-2mm difference on them.
Can you buy the tyres and not fit them?Costco... £230 for 4x 2254018 f1 assy 5s...
Going to buy them
I'm having them fitted. Only £7ish per tyre extra.Can you buy the tyres and not fit them?
I want to store them in the garage.
It says you have to pay for fitting when you checkout?
Going to buy them
Going to buy them
Just got 4x Eagle F1 Supersports in 235/35/19 from Costco.
£100 off with the Goodyear promotion too.
£417 fitted. Couldnt find them cheaper anywhere else.
How are tires so cheap there?
When I got my MPS4S I found them priced incorrectly on Walmart so bought 4, $225 each. Normal price is $330! 265/35/20
£170 for two?!Good price.
I'm booked in tomorrow for 2x F1AS5 in that size for £170 fitted via black circles.
£170 for two?!
Costco is selling them at pretty much £50 each plus fitting. Black circles are making some money eh
