£500-600 gaming pc. Realistic?
Under settings then I assume a tab called boot settings or boot order, you should have options to change primary SATA device or so on. A closer look to make sure the usb is even seen by the motherboard is an idea. See what we've got
No DVD drive, unfortunately.
https://imgur.com/a/lRa2cNb
I belive that is what you were referring to
This Should be first to boot from the usb key to install windows
Damn. Have a post limit so cant reply to you tamzzy.
Thanks, Tamzzy but unfortunately I get "Reboot and select proper Boot Device" message still.
Have gone through all USB options to no avail. Gone through several videos etc and doesn't seem to help. I think it will possibly be the boot drive but I've followed instructions exactly as given. (Incase you missed it I'm creating it on mac, as this is all that is available to me currently). Wondering if it is still at fault.
Hey all back again. Bloody post limit crept up on me yestersay :mad:
It appears mac wasn't doing whatit said it would. By chance brother was passing with laptop today. Used windows media creation tool and bam, worked off the r bat.
Up and running in windows. Question next is, is there anything i should be doing with OS or software to tweak the system at all?
Have done all windows updates.
Hey all!
Just wondering if it something i'm doing / not doing and how to fix the issue.
So i have the RX 590 installed. Had the PC built for 5 weeks or so now and runs fine under basic use.
I have put a lot of time into Rocket League and for the most part it is completely playable. I know that my monitor (Old Asus VP228 @ 60hz) is not up to scratch and looking to replace however at time performance is absolutely shocking!
Rocket league - 60fps - completely playable
COD Warzone - Had so much screen tearing and performance issues at a measly 14fps i had to step off.
Fallout 76 - Started playing yesterday. After install booted it straight up and seemed very good, no stuttering or tearing (didn't check in Radeon software for performance). Booted it Fallout 76 today and the picture has shot to **** and GPU/VRAM Usage were both at 100% and running at 14fps!
I have left settings of the GPU untouched so unaware what the problem could be? I've tweaked in game settings to try and help them along but now no joy. I know the monitor needs to be updated but considering was pretty slick yesterday and pretty shocking today i just cant get my head around it!
Latest drivers installed.
Any help appreciated. Thank you
EDIT: Forgot to mention. On occasion i will get black screened and then unable to recover. Seems that the connection to the monitor drops and i have to force a restart.
