Thanks all. I know have very flat feet so I'm going to try some insoles. The running pace is no problem, very easy so I suppose I'll keep at it. I know that I can run longer without arch pain than this time last week or the week before so perhaps it is just persistence!
It's typical Vitality of terrible development though. It was meant to start yesterday but it's pulling in a run from Wednesday. But only the morning one, if you're going to pull in runs from the wrong day, at least pull in both of that days runs!
EDIT - Done
https://app.runningworldcup.com/teams/invite/i5pp6q?ref=8ocsre
running injuries are a result of accumulating training stresses with insufficient recovery.
Dont be persistent in running through pain. There should never ever be pain while running. There can be minor discomfort which from prior experience you know will go away of you reduce training load.
Even if 1 week has the same or less traiy volume as the week before, you can still be insufficiently recovered as the accumulation of stress occurs of a period of weeks and months.
What you need is patience in increasing running volume. One thing about running is you can never buy gear that alleviates an issue in training or running form.
But, where do I go from here? That's the bit I'm struggling with.
To update. This has made it worse. 11 min/miles feel comfortable from a conversation point of view but, I've pulled up after 5 minutes with pain in arches. Next step just start again from week 1?
What has made things worse is you haven't recovered and you are basically injured. Take 1 week off from from then do a test run, soemthign very short even by your standards. If there is still a problem wait another week. If things feel OK then slowly add some more runs that are slightly longer E.g, if you normally run about 39 minutes then start with a 7-8 minute run, if that feels OK take 1-2 days off then try a 10 minute run etc., slowly building back where you were. If the pain comes back then you need to take another week off and repeat this doing a slower build.
Thank you, this seems more reasonable than starting again. Didn't recognise that I'm injured as the pain only presents whilst running. I've seen a tennis ball used as foam roller is a good idea for my week off.
Would this be a strategy throughout a runners career?
It can be very easy to get running related injuries which 'disappear' as soon as you're not running and flare up as soon as you start running again.
As DP says, the key is sufficient rest and a gradual build back to where you were.
It's easy to get frustrated with injuries and end up resting for weeks, then pushing yourself too much when you do finally start back. If I've learned anything from my injuries it's been to keep yourself mentally motivated (don't just give up in frustration) but not to rush yourself physically just because you want to get back to your 'best' asap.
oh yeah, Barcelona Marathon is cancelled so I don;t have to make that decision. Just worried that this super long training cycle will be for nothing as it looks like most major races will be cancelled.
