Progress is a lot slower than i had anticipated. The electrician' is so unreliable he is holding the job up massively.  The builder and carpenter; cant do much until all the electrics are in
Its still a mess.  However the garage is coming together and it almost be impossible to tell there is a room behind due to the size of the garage. I suspect should I ever come to sell the property this would not put people off.
Garage Jobs Left:
Electrics to be finished x2 sockets above and below worktops.
insulation to go into roof above new room
Wallpaper  plasterboard (brick effect)
Wall brackets for lawnmower
Clean garage out
Office Jobs Left:
Electrics -  several points, WiFi thermostat, outside lights
Underfloor heating, insulation and flooring
Skirting & Coving
TV mounted
Office desk fitted
Glass fitted in doors
Finish painting
Outside landscaping (entrance)
