Pic: Your desk...RIGHT NOW
Well if you print ABS do it in a well-ventillated area or use an extractor like^. Mine was in my small room with me and suddenly I got an attrocious sore throat and horrible taste in my mouth. It's pretty toxic.
That's good to know, I didn't know about that actually, I do have a window right next to where I'd most likely put it anyway so sure I could rig up something with that dryer pipe stuff and a 120/140mm case fan
I kind of disagree as I used to have lots of old hard drives with lots of useless junk on them all that been built up over many years of downloading & saving crap
Like I plug in one these old hard drives and have 50,000 files of crap like 20 year old versions of winzip, win rar, nero etc
Yes better to clear that stuff out. Most of my storage is home vids, astro image raw data and backups for all the PCs I have. One of the NAS's is simply a backup for the other one.
WFH for the next few months at least. Now I can properly
From this
To this
I bet you wish you done that well before now!! Great setup :)
Thanks
I never wanted the guest room to be an office but the C word has forced my hand. It certainly is easier working from home now.
Some great setups here, makes mine look rather boring. I was going to go for a desk that had a keyboard shelf and bookshelf built in but looking at the photos they were all like 8000 piece jigsaws with individual bits of mdf.
The desk I got came in 2 large pieces with 2 table legs and a few screws, much easier
New'ish chair, plants and put the ugly printer in a cupboard:
So elegant. So clean and all that hi-fi black. Love it. Looks like a great place to work. Minimalistic but oozes so much elegance.
To utilise our space better, I decided to get rid of our office downstairs and make it into a more kid orientated room. PS4 etc in there for the two older kids, youngest has all his toys in one room.
We have a large, fairly wasted space upstairs on the landing so I moved my setup up there. My other half who was also in the office, and a keen gamer, was then moved to what we call the snug. Gaming wasn't the same with us split up so I decided to go to Ikea and sort her a desk.
£500 odd quid later buying desk, chair, monitor etc...
I can't believe how everything just fits so well, obviously I measured prior to getting the desk but to get one that matched the width, height and length perfectly was surprising.
I'm really happy with the look, she just needs some accessories for her desk now. I'm setting her up a mini PC so she has something to use other than her Chromebook at the desk.
We both WFH regularly so another desk is handy.
Also, I can't believe how poor the quality Ikea desks are now. I first bought my Galant 7 years ago, it's so well made. The ones now are so poor and cheaply made. I know it's Ikea but still, bring back the Galant and it's robustness!
Love this little crib you've got going here. Very cosy. :D
The personal and work station for the next 12 weeks at minimum.
Another elegant one.
Took a couple snaps this morning of my setup now I've added the new Sonos and the little succulent.
So I moved away from Mac recently back to PC. This obviously meant a major change to the setup. I put together a custom loop in the Fractal Define 7 and this thing flies and is super quiet.
PC Spec
Case: Fractal Design Define 7 Mid-Tower Case - Gunmetal Grey Light Tint Tempered Glass
Motherboard: Gigabyte Aorus Elite X570
CPU: 3900x
GPU: Asus 5700 XT
RAM: 32GB 3600hmz Corsair LPX
Fans: - 6 x Noctua NF-F12 chromax
- 1 x Noctua NF-A12x15
Rads: - EK Water Blocks EK-CoolStream PE 360 (Triple Fan) Radiator
- XSPC EX360 Crossflow Radiator V2
Blocks: - EK Water Blocks EK-Velocity Digital Addressable RGB AMD CPU Water Block - Nickel + Plexi
- EK Water Blocks EK-Vector Radeon RX 5700 +XT RGB Graphics Card Water Block- Nickel + Plexi + Back plate
- EK-Quantum Momentum Chipset Aorus X570
Res/pump: EK Water Blocks EK-Quantum Kinetic TBE 200 D5 PWM D-RGB Pump / Reservoir Combo - Plexi
Fittings: EK-AF black x many
PSU: Seasonic Focus PX-750 750W 80+ Platinum
Storage: - 1TB ROCKET NVMe PCIe M.2 2280 Internal SSD High Performance Solid State Drive
- 1TB 860 EVO SSD 2.5" SATA 6GBPS 64 LAYER 3D V-NAND SOLID STATE DRIVE
Misc: - Mayhems X1 Clear Premixed Watercooling Fluid
- Mayhems Ultra Clear Watercooling Tubing (3/8 - 5/8) 16/10mm
- EK Water Blocks EK-UNI Pump Bracket (120mm FAN)
- Phanteks Extension Cable Combo Kit - Black/Grey
- Thermal Grizzly Kryonaut High Performance Thermal Paste
Peripherals
Keyboard: Durgod Hades 68 - Gateron silent browns - custom PBT keycaps
Mouse: Glorious Gaming Model D matte black
Mat: Cooler master MP510 XL
Speakers: Kanto YU2 with S2 stands
Sub: Kanto SUB6 matte white (undet the desk).
Headphones: Philips SHP9500 + Boomprod mic
Monitor mount: Duronic Single Monitor Arm Stand DM351X1
Monitor: LG 27GL850-B
Plans are to towards the end of the year upgrade to a newer GPU. I have a custom braided cable coming for the keyboard.
The setup:
The PC:
Build: https://forums.overclockers.co.uk/threads/first-custom-loop-in-a-define-7.18880132/
