What have you done to your car today?
So this WEEK I have done the following to my Civic:
- Installed a reverse camera
- Got my heated seats functional. I installed a leather interior from a donor last year and it’s annoyed me that the front seat heaters weren’t functional as my car was missing the loom. I finally sourced a donor loom but I had to strip so much other wire to get just the heater loom.
- Treated my plastic trim to make it black again:
I usually replace the cabin filter once to twice a year depending on how grey the white side gets regardless of what service may or may not be due. I recall from the manual the cabin filter should be changed every 15k miles but some cities/seasons see a lot of pollution in the air and under a year's of use highlights the state of the old one!
The other mad thing is how much these have gone up in price. I used to buy the exact same one for £11 18 months ago, it's the later generation with the additional filtration for fungus/bacteria and stuff yet as of this month even the standard activated carbon one from BMW is ~£60. Thankfully ECP sell them with the usual DFS codes but still ends up a tenner dearer than previous years.
Changed a couple of the more dubious looking coolant hoses on the wedge and in the process resolved what I think was an air lock it had had for a little while. Coolant temperature now comes up much quicker and the fan actually engages!
Like you, I tend to change the cabin filter twice a year and I’m awaiting mine from ECP. Like you I also noted the increase in price!
I always forget to change cabin filters, then I remember when I see someone else has done it. :p
Plus I've had several cars which don't have a cabin filter at all.
Yeah, they're normally overlooked, even by dealers. It's amazing how quickly they collect the crud.
Ours isn't too bad to change, despite being located behind the glove box.
I wonder what else has doubled/tripled in price in recent times now :p
Coke cans won't hold them in place man :D
ECP seem to have increased their brake fluid prices massively, used to be able to pick up 500ml pagid stuff for under £3. It's nearly a tenner at the minute.
I always get the Typ200 brake fluid. It's a shade over a tenner (or was) but an entire can gives you enough left over at the end.
Edit*
Just checked and typ200 on ECP is now £25!!!! I still have a full can remaining with the leftovers from previous fluid flushes meaning the extra price has valued itself into a full flush for the 3rd fluid change I guess.
Used some loctite sealant to try repair my air straightener on the corksport MAF housing..so far it seems promising, gave it a wack and shake test its not falling off so good start.
Buy a new one, not worth the risk of it coming apart and being ingested the the turbo and beyond
20mm spacers on the mx5 today, 40mm per axle - the wheels just flush with the plastic bit of trim now although it will be tucked back in a little after the springs go on as a 30 odd mm lowering should pull them in by 5-10mm.
