Apologies if any uploades pics are massive - hard to tell from mobile uploads.
I'm now on furlough leave after working from home a couple of weeks looking after my little man. My other half is still working (but her usual 3.5 days a week and from home) so although my riding has picked up in the fantastic weather I've kept it sensible (unlike many on my Strava!). Only once riding for any real time over an hour (but it was under 2). Absolutely LOVING the weather and if this is a sign of the summer it will be a great one. Fingers crossed for that and the whole lockdown/not-a-lockdown situation on Thursday to not drastically change into an absolute lockdown (although won't surprise me if they do).
I've had a few issues with neglecting any real maintenance for the last few months... Climax of this was a SRAM chain breaking on me and the sideplate gouging some horrible amounts of paint, lacquer and dare I say it... Carbon out of my frame below the BB/behind the chainset. Probably hard to really tell from pics but what are peoples opinions on this?
I personally think it's 'safe' to ride as is just ugly surface damage in a non-stress/low-stress area. None of the gouges (there's 2 big ones) are deeper than 1.5mm including paint in that measurement too. How would you cover/protect the carbon below that? I've used nail varnish on my alu I frame but seem to recall that can eat carbon resin.
I rode that segment with a chain link about to break
Wish I'd read this before the above happened as might have influenced me to do something more with what I found!
Did a good clean (well overdue) and noticed when I inverted and took wheels out/off where the chain was lay on the RD that the link there was missing part of the sideplate. Thought it a little odd as although the chain had been abused over winter and spent most of it's life filthy, it wasn't 'old' and feeling ok. So just cleaned it up and put a QL in place of it. Didn't look for other links with problems or think too much of it as just wanted to get out and ride... Bad mistake!
Also replaced rear RD cable and inner. Also switched my FD from the original 105 5800 to the new style Ultegra R8000. Wow how overly complicated is fitting one of those!? Still followed a good YT video and got it sorted quickly. But such a sequence to fit and do cable routing correctly. Although I am now really pleased how tidy it looks and how well it operates.
Got out and rode! But the clean I'd done had obviously upset a front wheel bearing and had to cut things short due to the horrific squeaking/squealing it was making.
Changed front bearing but only had 1 new the right size so ordered 3 more so at least I can pair up and have a spare pair still. Before the next ride changed rear brake pads but in doing so pulled the freehub off the rear axle when refitting the wheel. Dammit! Really annoyed but stripped and cleaned the freehub out. Bearings feeling fine so left them (rear is a couple of years newer than front as popped a spoke).
Felt good!
Mildly annoyed by all the sudden maintenance headed out again... Half way around the bar tape on the left drop had popped out the cap and was slowly unwinding every time. Should've taken that as an omen and just headed home...
Didn't and continued with my loop, then under 2 miles from home putting out a bit of power to overtake a mobility scooter on the cycle path the chain just popped and jammed behind the cranks. Annoying. I've never really been one to drop chains, have maybe done it 3 times in nearly 10 years of riding. First of all just thought it was that. On closer inspection ripped apart chainlink! Gutted to see some of my hyper-green paint on the torn metal...
Popped a spare chainlink in and got myself home. Damage is covered above, but basically guys look out for any of this happening to your side plates when running SRAM chains!
And a nice deep gouge on my chainring...!
#wattbombs!
@Roady thanks man
Wee man doing very well. He's lean and long. So we have made a future GC dude.
Good to hear buddy, scary times bringing a wee one into the world at these current times. So please keep them all as safe as you can!
