YepWill do, keep my SOC voltages the same for now?
Foud it although some the values in the DRAM calculator don't have a corresponding entry in the BIOS.
Also, where do you find the BGS setting?
Yeah, where?!![]()
I have found the BGS.
I have entered all the values as per DRAM Calculator.
The PC boots but some times in Windows everything hangs, particularly when you open a program, even CPU-Z doesn't load properly.
What next?
Safe.
I haven't had the 8d error on 2.10 with xmp on. Only started occuring on 2.80, and not all the time. I've got ram voltage up from 1.35 to 1.375 which so far seems to have sorted it. Using 8 pack branded memory.
