Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Entry level for a good quality, consistent, low retention espresso grinder, 300-500 range is where you'd look to start.
I try to avoid falling into the trap of buying cheap, twice, or worse, buy cheap, then buying decent!
That’s my philosophy too, camera gear I tend to go for the higher end lenses straight off because I know eventually, I will end up there so I see buying something for £300 (selling for £200) because getting the lens I really wanted later as £100 lost.
That said, my current grinder MC2 has been going for 13/14 years, paid £110 for it so I have had my money’s worth from it and then some. This next grinder would be something I would use for the next 10+ years, if not, forever.
I like the simplicity of the Niche, less to go wrong.
