- 26 Sep 2017
- In the Masonic Temple
My wallet is open and in my ass they can pick up the cash on the way
https://videocardz.com/newz/nvidia-says-get-amped-for-gtc-2020-keynote-on-may-14
I ultimately will be happy to fork out for this due to the fact I've had my 1080ti 3 years now. I'm ready for something else.
I am really struggling whether I should build a home gaming desktop with AMD 4000 and 3080Ti and then just enjoy it for the next 3-5 years (which actually makes it a reasonably palatable investment)... or wait for the notebook version and buy a badass gaming laptop (which will last me less time and is more prone to unfortunate accidents like me spilling drinks on it).
I said I would never build another desktop system, but that was before AMD came back on the scene and now I think the chances of getting an AMD 4000 mobile CPU with a high-end Nvidia GPU are pretty much negligible for the forseeable future thanks to Intel's pressure on their partners.
I am leaning towards the desktop option, which would likely be overkill but would last me ages even at 4k resolution with the games I like to play. I could also run a 20m HDMI cable to my living room TV and have the option to game in there on the big screen if/when I wanted.
If only there was an external GPU enclosure with connectivity that had no loss of performance... it would make things much simpler as I could then get a notebook like the AMD G14 and have the best of both worlds. Sigh.
Will stick with my 1080ti unless there are some severe price cuts across the entire range.
I probably spend about 5x less on PC hardware than most other people in this thread... 1 upgrade every 3 years is certainly not excessive!To afford a 3080Ti...You indeed must be a Rich Dog![]()
Lets all hope for no higher then around these prices
3070 = £750
3080 = £1,000
3080ti = £1,250
And im calling it now they won't be called 3070etcNah way to high.
I expect similar prices to now.
3070 £500
3080 £650
3080ti £1000
Although there is too much of a gap there between the top two cards.
PC Gamer suggests this event will be for AI, deep learning and professional graphics although maybe a hint of end user stuff. I bet they don’t the gits. https://www.pcgamer.com/nvidia-ampere-gtc-keynote/
Yup it does seem strange that so far only Apple have realized that the number 11 follows 10, but with NVidia already having the 20XX series i suppose 21XX would be too much for hope for so 30xx would be the next logical choice.
nVidia will only use 11, 21, etc. (or 16) for refreshes, etc. they also don't seem to like the number 3 for some reason.
