My battery life has actually been brilliant since the update
I liked the compact design. I went from small phone to pixel 2xl and kinda wished I still had something smaller. The new iPhone came out and kinda got me thinking about small again. So many phones to choose from doesn't make things easy.I loved the phone when I had it, I only changed to OnePlus 7T Pro because I got screen envy
If you're set on a compact phone with flagship features for a reasonable price there's nothing better out there IMO.
If you're main concern is budget you could consider the S10 Lite but it's a different beast entirely.
read a lot like this.I'm one of the worst affected S10e users here with battery life and basically half a day usage (3ish hours SoT), but if you're able to top up at work or car then you'll just about get through the day. Also note that battery life is only pants on mobile data and not Wi-Fi on which I can get up to 7 hours SoT.
Occasionally the phone throttles if I'm in an area with poor reception and have the GPS on as well (I do a lot of hikes and go running), so definitely invest in a power bank if you're going to be away from chargers. I am one of the worst affected users and most seem to be getting almost 5 hours SoT out of theirs so my advice, if your battery life doesn't improve after a week of use, just return it under the 14 days if you can't live with that endurance.
As for the rest of the phone, I do still really like it. Excellent ergonomics and size (had P30 Pro and Xperia before it), good performance, cameras and usual great Samsung screen.
which did you prefer between p30 pro and s10e?I'm one of the worst affected S10e users here with battery life and basically half a day usage (3ish hours SoT), but if you're able to top up at work or car then you'll just about get through the day. Also note that battery life is only pants on mobile data and not Wi-Fi on which I can get up to 7 hours SoT.
