- 3 Mar 2006
- wakefield
I think you should read my post, and then your post again.
Firstly, this is the desktop CPU thread, not laptop. When I correct you, and advise that Intel is still king of mobile gaming performance on laptops, you can't seem to accept it. I'll try break it down for you buddy:
Gaming performance is primarily based on GPU performance. You can't buy a AMD Ryzen laptop with anything better than a RTX 2060, so Intel will automatically win, no matter how good the Ryzen 4000 mobile CPU's are. This is for gaming of course. So your point is moot - for laptop gaming performance at the high end, Intel is the only player and has the best gaming performance.
You'll also mind the vast majority of AMD laptops have 'bad' displays, while the Intel ones have the premium 100% SRGB IPS displays, further crippling AMD.
Zephyrus G14 should have better gpu options imo corker of a machine otherwise
