snip[/MEDIA]
.You will probably have to enable the port forward on your router as it will be blocking the inbound connection otherwise.
Details here: https://portforward.com/streets-of-rage-4/
I'd imagine the STEAM one and XBOX pass share the same ports.
i have this on gamepass pc and it was working fine last night, now it wont launch, the splash window comes up, sits there for a min and then just closes, anyone else having the same issue?
Loving it so far, but my god first go on normal and i got wrecked, think i will have to go through it on easy first
probably tried it about 4 times, getting to the same part of the fight.How do you defeat the boss at the jail, I can't get past his riot shield!
Please people, don't give Microsoft ideas and buy this somewhere that isn't Windows store. That needs to die
Did you manage to figure this one out? Just got to hit them in one or two punches and step back as they are about to hit you, rinse repeat and should have shields down in about 3 turns.
I've had a look at the steam exe, can use the usual hex edits for aspect ratio, I can get it to fill the screen but the fov is all zoomed in, needs a hex edit for fov but I can't find it.
Good news is it looks possible, bad news is we need someone who knows these things to look at it.
Edit: Someone on steam has claimed that it will not be possible as he watched the digital foundry tech review and nothing exists outside of a 16:9 boundary plus the aspect ratio is tied to how you touch the screen edge to proceed.
Unsure how true that is.
