What have you done to your car today?
Kei
Kei
24 Oct 2008
South Wales
Spent the morning swapping out the offside rear wheel bearing.
JRS
JRS
6 Jun 2004
Burton-on-Trent
Pulled the dashboard off Desdemona as part of an attempt to swap out a broken choke cable for another one that we had. No dice as it turned out, for several reasons. So we just soldered a length of extra cable on the end of the existing one (which in retrospect is exactly what I should have done days ago) and stabbed the dash back together.
20 Oct 2002
Northampton
Lifted the engine out of my golf today, gearbox and turbo now off, plans are to strip it down and check the block, if its still OK then the block will go to a machine shop for a bore out to 1.9L so the rebuild can begin!
Im going to aim for around 320 - 330HP with forged rods, pistons and a hybrid turbo. while the engine is out im going to tidy the loom and engine bay as it needs a lick of paint and some proper heat shielding at the back.
*sorry for potato quality pics*
16 Mar 2004
Oxford
Spent a couple of hours on the Focus ST on Friday, cutting off the standard Ford exhaust system and replacing the mid-section & back-box for a Mountune equivalent. Could have been easier but the bolts between the cat & mid-section were in a rusty state so WD40 & a hammer was needed.
Sounds a lot better now, making the already great sounding 2.5T sound better (not stupidly annoyingly loud).
27 Dec 2005
Bristol
I guess this counts! Finished setting up a Raspberry Pi with TeslaMate to record and display data streamed from Tesla's API. One of the overview pages:
Other pages are incredibly detailed! Cost/use per charging destination will be useful amongst a whole host of other stats.
Shame I'm not going anywhere at the moment...
25 Oct 2014
East of the Middle
That looks awesome! How difficult to set up?
27 Dec 2005
Bristol
Not at all really. I only needed to utilise some vague knowledge of SQL to create some custom panels on that dashboard but you could probably get by without. Otherwise I've never used a Pi before and apart from the usual troubleshooting - mainly network issues - it was straightforward. Most people that run it over on the Tesla forum have zero coding/programming knowledge.
2 Jan 2012
Awesome
7 Dec 2011
Not so much what I have done, but am going to do today...
My wheel came back from Royal steering wheels last week and is looking smart so will finally put it back on the car
Man of Honour
13 Nov 2009
Northampton
