So we're over 3,000 posts without a product. I reckon there's a decent chance of 4,000 posts before we get the professional products and a 90% of 5,000 posts before the consumer products.
Ampere doesn't necessarily have to be more than 30% uplift over turing to be a solid justification to upgrade for those on pascal.
Yeah but if you have been following this thread the rumour is only high end stuff like 3080Ti and upwards is with Samsung.My main concern is if Nvidia,is using Samsung 8NM,as Samsung is mostly using that for smaller ARM based SOCs,so we don't know how well it holds up if Nvidia is mass producing much larger GPUs,ie,will yields be OK?? The only GPUs made by Samsung for Nvidia were smaller ones such as the GP107,which actually was a bit worse performance/watt compared to the TSMC made Pascal GPUs.
This is partially what happened with AMD when they moved from TSMC to GF/Samsung 14NM,which was a worse process than TSMC 16NM. There was evidence Polaris despite being a safe design based on the earlier Fiji/Tonga(Polaris was an evolution of the latter GPUs),it had to go through many production revisions. Then you have Vega,which in IGPs seems a very good design,but had lots of problems in the larger versions.
My wallet is saying 3080, but I'm sure I'll be tempted by the enthusiast priced top end card.Which card do you expect to be upgrading to RanxZy?![]()
Yeah, lol. We will see soon, not too long now. Got enough games to complete on my Steam account until then with my RX 580According to Moore's Law is dead it's the opposite. I think someone must be wrong but I've no idea who![]()
I think they will try and release the new cards before the new consoles come out maybe I'm wrong .
Pretty sure they will. You going to upgrade to a 3070?I think they will try and release the new cards before the new consoles come out maybe I'm wrong .
I might have to spend a Sunday evening down on the docks. At least then I should be able to afford to buy the cardboard box it comes inMight have to work a Sunday as not to dip into my savings![]()
Yeah. I am looking forward to the PS5, though it will likely take a couple of years until we get some decent exclusives and games that are made from ground up that take full advantage of the new consoles. So I may just hold out and grab one then. Should hit £300 by then alsoI wasn't too optimistic about PS4/Xbox 1 at the time of their release partially due to the pathetic cpu they both have and the gpu power were around 7870/7850 respectively which at that time us pc gamers had access to much more powerful hardware (290x / GTX 780 Ti) this time I'm very excited for the new consoles! SSD as a standard drive which a lot of pc gamers I would imagine doesn't have a dedicated ssd for games. Also the cpu is much closer to the high end also the graphics performance if true around RTX 2080 performance + console overhead meaning it'll use it's power more efficiently vs pc so yes... consoles are definitely looking promising if under £500 with a game!
The 2080ti is going to go down as the worst gpu purchase ever isn't it.
**** me if the rtx3060 matches the 2080ti and only costs $399
