Unigine Heaven 4 benchmark
6 May 2009
Is the following quite low for 2080Ti, i7 4790k @4.5ghz?
It seems I should be getting 4700+ as 3600 is lower than some 1080Ti's.
All games and higher res working fine
Unigine Heaven Benchmark 4.0
FPS:
144.3
Score:
3636
Min FPS:
36.5
Max FPS:
257.1
System
Platform:
Windows NT 6.2 (build 9200) 64bit
CPU model:
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (3999MHz) x4
GPU model:
Citrix Indirect Display Adapter 12.40.44.247/NVIDIA GeForce RTX 2080 Ti 26.21.14.4578 (4095MB) x1
Settings
Render:
Direct3D11
Mode:
1920x1080 8xAA fullscreen
Preset
Custom
Quality
Ultra
Tessellation:
Extreme
30 Dec 2013
Liverpool
FPS:
144.3
Score:
3636
Min FPS:
36.5
Max FPS:
257.1
System
Platform:
CPU model:
GPU model:
Settings
Render:
Direct3D11
Mode:
Preset
Custom
Quality
Ultra
Tessellation:
Extreme
Your CPU is holding you back. I have the same and at 4.9ghz it holds back a titan Xp in some situations when the fps is high
6 May 2009
I thought this but no.5 is similar to my CPU, over 1000 points higher though
Score 4864, GPU 2080 Ti @2025/3850, CPU 4770k @4.5, Biffa
edit - I am using 26.21.14.4578 (Nvidia 445.78) / Win10 64 Beta driver.
Not sure if this has any effect on Heaven 4 benchmark
6 May 2009
Disabled the Citrix Display Adapter however it still shows up in the Benchmark run so don't think there is anything I can do about that.
I tried the same. I am a Citrix engineer so sort of need the display adapter for testing... might get rid of it though :D
Edit - tried uninstalled Workspace and HDX plugin, not much difference. Scored 3646 for 1080p
6 May 2009
Yeah we use Citrix for our remote connection with virtual desktops so need it every day and I can't really be bothered at the moment to uninstall/reinstall.
Same, but forgot ive got test machines in my draw. It can stay removed for now until i need it on full pc
edit - Sorted. Retested with Gsync disabled and now get 4436 on 2080Ti stock settings, seems about right
EVGA GeForce RTX 2080 Ti XC GAMING @ stock
i7 [email protected]
EVGA GeForce RTX 2080 Ti XC GAMING @ 2025/3850
1 Sep 2004
Northants
Re ran the benchmark with increased GPU clock speeds;
Gigabyte GeForce RTX 2070 SUPER WindForce OC 3X @ GPU Clock: 1715Mhz, Memory: 1950Mhz, Boost: 1895Mhz
Ryzen 3700x @ 4.4Mhz
6 May 2009
Ah, my bad! :(
10fps min which should be quite a bit higher. I bet it underclocked/stepped down briefly to cause that.
Maybe try dialing it back a bit and you might get an overall higher score
6 May 2009
Re-ran it again after a reboot;
Nice, though the Heaven 4 benchmark (especially at 1080p) is rather pointless really now in my opinion.
My 1080Ti at stock settings and same i7 4790k @4.5ghz cpu scores 3692 marks. Better in recent games, doubt it
I've had the following cards and noticed with benchmark heaven 4 generally that;
780Ti is around 40% slower than 980Ti
980Ti is around 40% slower than 1080Ti
1080Ti is around 40% slower than 2080Ti
