NiceChip set fan, what chip set fan?
Sits around 27c.
Here's the chip in question.
Block installed.
Would only fit if the GPU is water cooled.
What case and watercooling gear your got there?
Sits around 27c.
Block installed.
Nice
Thanks. Might consider doing something like that for a long term build in a few years time if I go Zen 4It's the Define 7 and it's all EK except the tubing, I have a thread in the project logs with much more info - https://forums.overclockers.co.uk/threads/first-custom-loop-in-a-define-7.18880132/
Nice build.Chip set fan, what chip set fan?
Sits around 27c.
Block installed.
Sits around 27c.
Block installed.
Can someone tell the main benefit's of X670 over B550? is it just purely overclocking, more expansions and bandwidth?
i'm using 1080ti with 4770k so its bottlenecking atm.
I'm considering buying 3300x / b550 in june with some 3600mhz dark pro ram and an 500/1tb nvme. then upgrading cpu to 4600x/4700x/4800x when that comes out later this year.
Is it worth holding out for X670. I'm not playing much atm only warzone and some casual wow so not in desperate need at the minute. waiting for cyberpunk, ac valhalla, wow shadowlands. Only used for gaming no streaming or editing.
I will be looking at X670 tomahawk / b550 tomahawk
X670 Probably wont be out till the end of the year if at all. If you want to grab something now its either X570 or B550 in a month, the x570 tomahawk does look a good shout though if you can find one.Yeh got it OC'd to 4.3 atm. It's no problem to buy and sell. Don't want intel, going team red.
Just seen the Z490 board details - 3 active fans. .
Pointed 12cm fan and fan rarely goes faster than 300/450rpm. And temperature, even under load, very, very rare to cross 60C.Reading various user reviews it seems the chipset fans are averaging 55-60c in a brand new system that has no degradation or dust buildup, with current ambient temps 15c lower than the height of summer. Considering the fans kick in at 60c it won't be long before the 0rpm "silent" mode disappears for most users.
The fan itself is rated for 60,000 hours or 7 years when run 24/7. My current PC has been running 24/7 for 8 years and its replacement is expected to last just as long. In that time I've had to replace most of the fans to retain a quiet system.
A not so bold prediction - Every summer for the next 5 years this forum will be flooded with complaints about the X570 Chipset Fan.
Worth noting that the 60k hours figure is operational hours (I know you understood that hence the 24/7 calc but some reading may not), for the average motherboard it will take decades if not centuries for one of the PCH fans to actually hit it's life expectancy.The fan itself is rated for 60,000 hours or 7 years when run 24/7.
