A drop to 10fps usually indicates (or has for me) that the overclock is not stable. The gpu/cpu will throttle right back causing the low fpshere's my updated score.
running a 3900x overclocked to 4.4ghz all core, g.skill trident z neo 3600mhz set to 17,20,20,38 and a zotac rtx 2080ti (core @2100mhz and ram @8000mhz effective) all under custom watercooling from ek, my ram's letting me down cl17, but i have some 8pack ripped modules on order (cl14) so may take another crack at it
getting stutters at the beginning of some scenes too, what could be causing that? (castle part at night especially)
, gpu hovered around 2085mhz instead of dipping down to 2020mhzI would expect a newer cpu like yours and higher overclocked gpu under water to get into the 5000-5300 score range
, but i have on order some 8pack ripped 3600mhz cl14 which should give a nice boost once installedNot sure on that to be honest as havent heard of cl18 memory but have been out of touch with RAM/Motherboard and CPUs for some time now.i have cl18 ram atm which could be down to lower scores, but i have on order some 8pack ripped 3600mhz cl14 which should give a nice boost once installed
I'm using some old DDR3 stuff from years ago. 4x4GB sticks of HyperX.
CPUZ says;
DRAM frequency 800Mhz
FSB : RAM 1:6
9,9,9,27,128, 2T
PC3-10700 (667 Mhz)
XMP 1.2
I hope I've done this right. What are the 2 figures in the GPU clocks?
Score 4454, GPU 2080 Ti @ 1650, CPU 10980XE @ 3.0, Coojeekitten
very nice score piped me by less than 10 points, a tip try enabling max power mode with in NVIDIA control panel, i did the same and noticed a fair jump in my score, you'll find your min fps will go up to around 30-50fps mark which will help the overall score by a few hundred points
I'll try that thanks. How do I list the GPU clocks correctly?
You're right, max power gave a small improvement.
I'm still not sure I know how to enter the GPU clock info correctly. :/
Score 4474, GPU 2080 Ti @ 1650, CPU 10980XE @ 3.0, Coojeekitten
have you got any kind of gpu monitoring software installed? if not get msi afterburner of gpu-z both will show the max clock of the gpu core and memory, gpu-z will allow you to show max, min and average of core and ram, where as msi afterburner will show the max clock the gpu core hit and the ram speed.
tbh i was expecting your score to go up a bit more, mine was 4220 and when i adjusted the power option i hit my pb of 4446
