Caporegime
- 9 Nov 2009
- Planet Earth
It wasn't people assuming support, it explicitly MARKETED future support.
They told a system integrator as far back as April,the B450 would work with a microcode update. It's been posted enough times here - the system integrator had to find out via the AMD official release,the same day we all did!
I suspect this decision is not so much pushed by AMD but by the motherboard vendours. AMD may loose out on the odd percent of 4000 sales but the motherboard makers will shift way more units and also save themselves some major headaches in the process with having to update older boards.
I had one of the original B450 Tomahawks and remember all too well the hassle and complaints they had trying to get what was probably the most popular B450 board to work with Ryzen 3000. I personally had no problem whatsoever, just did the flashback but many people didn't have my experience.
Probably the only thing AMD can to do now is ride rough shod through the cognitive dissonance caused by the gap between reality and the expectations of the majority of its patrons owning B450 x470 etc boards.
You had AMD making charts like the following:
It's not only DIY buyers but apparently even system integrators - just look at my previous post. Also AMD posts on social media,so for 12 months they have senior AMD marketing people post in the AMD reddit,seeing people post Zen3 should work on B450/X470. They said nothing. AMD even went on social media several times,to debunk rumours.
Plus if there was really problems with the B450/X470,they should have made a compatible version,ie,maybe call it the B450X or even launch a range of B550A motherboards(they did for OEM and these were B450 motherboards which had PCI-E 4.0),so there would be no confusion. They did nothing,and many OEMs released new B450 motherboards specifically for Zen2,just before or after launch. Those OEMs would have loved that too.
The same goes with the BIOS chip size. They design the reference platform,so it's their fault for not specifying a minimum size BIOS chip. OEMs,will base their own motherboards around the AMD reference design specifications.
So having looked over the specs for my x570 Tachi is would appear that I have a 32MB bios. Who is responsible for that? Is that Asrock or Amd?
ASRock I believe as many X570 motherboards use 16MB BIOS chips,like a number of B450 motherboards. My Asus B450 uses a 32MB BIOS chip too.
If AMD specified bigger BIOS chips,ALL AM4 motherboards would have. Seems the AMD specifications must be 8MB or 16MB BIOS chips.
I can even understand if this was for B350 or X370 but surely for second generation chipsets they could have specified bigger BIOS chips.
